16 Users Online (14 Members):
Forums >> General Discussion >> Wishlist >> Multiple bays of Framing for Structural
3 Posts No Rating |
When doing joist systems/beam systems in structural drawings, typically one will have a joist or other framing member at column lines. When using Revit's beam system command, you can go through and make a system from column line to column line. Fine. But when I want to annotate a long stretch of beam systems that are all the same members, i have to break up the tags by bay. It would be nice if Revit offered a way to set multiple bays at once. Max spacing at 4'0" oc from grid A - B, B - C, C - D, etc. Then when tagging the framing system, allow the span arrow to pick up all of the framing from Grid A - D. Thanks
Multiple sloping slab on grade |
Wed, Sep 28, 2005 at 11:20:27 PM
structural framing family cut pattern interacting with wall in section 2017 |
Wed, Sep 5, 2018 at 12:52:56 AM
Structural Framing Plans/Callout Beam Sizes |
Wed, Feb 22, 2006 at 5:49:10 PM
Structural framing tag |
Mon, Apr 5, 2021 at 1:29:32 PM
"Framing Member Ends" attached between bays |
Fri, Mar 18, 2011 at 1:11:29 PM
