Forums >> Revit Building >> Technical Support >> Porous skin
Tue, Mar 30, 2010 at 11:30:34 AM | Porous skin
Pdalt23
Would anyone happen to know where or how I could obtain this screen skin wrapped around this portion of this Morphosis building?
Tue, Mar 30, 2010 at 12:11:52 PM | Porous skin
How about one of the stock screen (perforated metal) materials in the materials library.
Tue, Mar 30, 2010 at 2:44:11 PM | Porous skin
Pdalt23
Does Revit 2009 offer this material you speak of?  Or is this in 2010?  Also, is there an upgrade for my 2009 material library?
Thanks
Tue, Mar 30, 2010 at 3:11:37 PM | Porous skin
You asked - "Does Revit 2009 offer this material you speak of?"
You know, it's that kind of question that just drives me nuts.  Do you have a broken finger?
Obviously, from your question, you don't even know what you have in your library so why ask about an upgrade?  Upgrade - maybe - 2010 - 2011.
Tue, Mar 30, 2010 at 3:35:06 PM | Porous skin
Pdalt23
Actually, I've looked through my library and can't seem to find it otherwise I wouldn't have asked that question.  If you actually believe that I was enlisting your services to look through the 2009 library for me for said material then you need to step back, relax, and quit assuming things so quickly.  If 2009 does offer this material and I haven't found it , which I haven't, then the next OBVIOUS question would be if there is an upgrade for the 2009 material library.
Thanks
Tue, Mar 30, 2010 at 3:46:01 PM | Porous skin
Look again... "How about one of the stock screen (perforated metal) materials in the materials library." 2009
Double Skin facade with folding shutters
Tue, Nov 12, 2019 at 9:31:43 PM
siding as skin
Wed, Feb 24, 2010 at 11:48:55 AM
Master Spec and Double Skin walls
Wed, Dec 28, 2016 at 5:40:21 PM
export dwg including a linked revit file
Tue, Jul 31, 2012 at 12:30:21 PM
Double-Skin Facade as a "Curtain System" on a "Mass".
Sat, Nov 21, 2015 at 7:10:28 AM
Page generation time: 0.0820
