Forums >> Revit Structure >> Technical Support >> How to show Wall Ftgs with hidden linetype?
Tue, Sep 20, 2005 at 9:21:51 PM | How to show Wall Ftgs with hidden linetype?
JAMIER
Revit Structure: The wall footings display in my foundation plan as solid lines and a concrete hatch. Typically structural foundation plans show footings as hidden/dashed linetypes with no hatch. How can I do this in revit. For my column footings I was able to edit the family to not display the 3d ftg object in plan view and than draw a symbolic hidden line over the footing so it displays in my fdn plan. Do not know how to so this with the continuous wall ftgs which I think are a system family. Thanks,
Tue, Sep 20, 2005 at 10:03:11 PM | RE: How to show Wall Ftgs with hidden linetype?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
setup your view range for the view so that the bottom clip plane is just above the footings, then have the view depth set below that of your footings. Elements located between these two planes are shown using the <beyond> line type. So if you setup your beyond line type to be dashed as appropriate it should give you what you desire.
"Level above" to show as hidden lines
Sat, Mar 18, 2006 at 6:15:59 PM
LINESTYLE OF HIDDEN STEEL COLUMNS
Mon, Jan 17, 2011 at 5:25:38 AM
How to add new linetype to family
Fri, Jan 3, 2014 at 10:01:49 AM
Showing objects in higher levels in hidden linetype
Tue, Feb 21, 2012 at 7:10:07 AM
Wall Hidden Lines and Object Styles
Tue, Jul 31, 2007 at 11:47:48 AM
Page generation time: 2.0955
