Forums >> Revit Building >> Technical Support >> Question about modify divided surface
Mon, Mar 29, 2010 at 11:03:32 AM | Question about modify divided surface
shenlunglinnk
3 Stars: 2 Votes
Dear friends
When I finished a *blend sweep form*, and would like to modify the divided surface, I noticed that the form was divided into 2 surfaces.
Thus if I continued to apply my own element type to these 2 surfaces, the borderlines could not be jointed.
How can I solve this problem?
(Please see the picture)
Thank you very much
Mon, Mar 29, 2010 at 1:05:15 PM | Question about modify divided surface
shenlunglinnk
3 Stars: 2 Votes
Hi again
In this form, the surface was even divided into 6 parts.
How can I make them as 1 surface to edit or to apply the element type?
Thank you very much.
Mon, Mar 29, 2010 at 1:06:04 PM | Question about modify divided surface
shenlunglinnk
3 Stars: 2 Votes
Oj
It's 8 parts, not just 6 parts.....
Mon, Mar 29, 2010 at 2:15:51 PM | Question about modify divided surface
4 Stars: 205 Votes
Try to play with those parameters... see the images
Mon, Mar 29, 2010 at 3:15:47 PM | Question about modify divided surface / How to choose surfaces at once
shenlunglinnk
3 Stars: 2 Votes
Dear Typhoon
Thank you again......:-)
So you mean there is no way to select them as 1 surface at the same time.
Then I have another question:
If I want to apply 1 material to a cube, I have to apply 6 times to those 6 surfaces?
Is there any posibility to select those 6 surfaces at the same time, then just apply 1 material once?
If my building has 100 surfaces, and I want them to have the same material, then I have to repeat 100 times?
Do you have any trick?
Thank you vrey much
Tue, Mar 30, 2010 at 3:56:06 AM | Question about modify divided surface
4 Stars: 205 Votes
Dear shenlunglinnk
About your doubts i must say one thing:
Learn to use the TAB key, go with your mouse to the object then TAB, TAB, TAB....
Edited on: Tue, Mar 30, 2010 at 3:58:29 AM
Tue, Mar 30, 2010 at 7:03:39 AM | Question about modify divided surface
shenlunglinnk
3 Stars: 2 Votes
Hi Typhoon
Now I get it....:-)
Because I could select the whole object at the same time in other 3d program, so that was why I asked.....:-)
Thank you very much
Have a nice day
Adding Material to Divided Surface
Thu, Apr 17, 2014 at 10:40:12 AM
Parametric Curtain wall panel in divided surface
Sun, Jan 31, 2010 at 8:08:54 AM
Void Mass Not Cutting Divided Surface Mass
Wed, Jan 31, 2018 at 10:19:21 AM
Void surface on divided surface
Mon, Mar 10, 2014 at 5:41:07 PM
How to cut mass conceptual divided surface
Mon, Apr 30, 2018 at 9:15:59 AM
Page generation time: 1.9182
