16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Angling Columns
Is there a way to angle a column, in particular a column that will be used to hold a verandah at the entrance of a building. e.g a column is usually 90 degrees to the ground but is there a way to put it on a angle of 80degrees to make it a feature?Thanks in advance.
You don't say what type of column and that would help. 2011 is supposed to have some better features for this problem. If you are talking about architectural columns, consider an in place family.
WWHUB, i am referring to an Architectural Column. I am a newb to Revit so im unsure what you mean by In Place Family
An in place family vs a loaded family.. An inplace family is simply created in the project and can not be used in another project. In-place families are best limited to one of a kind elements and are not meant to be used in multiple locations. Befire you seven start with this, find the Families Guide on the autodesk site and download that. It will go through the family building process. I would model this column in-place using a solid blend. How to do that will be found in the families guide. To access the Revit Architecture Families Guide, click (Help) drop-down arrow Families Guide. Welcome aboard.
hidden columns |
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above |
Mon, Jun 9, 2008 at 1:49:48 PM
Angling an existing hatch pattern |
Fri, Mar 5, 2010 at 11:37:31 PM
recalcitrant columns |
Tue, Aug 3, 2004 at 7:38:46 PM
Leaning columns |
Sat, Jul 2, 2011 at 7:56:56 AM
