Forums >> Revit Building >> Technical Support >> Basement Wall Function: "Foundation" or "Exterior"?
Fri, Mar 26, 2010 at 10:47:04 AM | Basement Wall Function: "Foundation" or "Exterior"?
ldonkle
We have a fundamental problem putting doors/windows in our basement walls.  Our basement walls have their funtion set to "Foundation", which means the walls come in BELOW the level they are drawn in.
But when we add a door/window, these always come in ABOVE the level they are drawn in.
So is there a way to make our doors/windows come in BELOW the level they are drawn in, or do we need to change our basement wall function to something other than "Foundation"?
Fri, Mar 26, 2010 at 12:27:21 PM | Basement Wall Function: "Foundation" or "Exterior"?
Don't use a foundation wall where you should be using a wall.  Revit considers foundation walls as part of foundations .,.. they won't act the same as walls.  Consider these walls as regular wall (bearing) but below grade.
Wall Trickery
Wed, Jan 19, 2011 at 4:33:38 PM
Create a "Foundation Wall system family?"
Tue, Aug 3, 2010 at 9:50:54 PM
Revit Architecture 2008 - Foundation Wall Tool works funny
Wed, Oct 24, 2007 at 5:32:29 PM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
Page generation time: 1.6983
