Forums >> Revit Building >> Technical Support >> Section through a family object and imported dwg file
Fri, Mar 26, 2010 at 10:05:20 AM | Section through a family object and imported dwg file
diesellam
Is there a way you can cut a section through a family and imported dwg file?I remember I could import the file as mass and explode it in Revit 2009, the section will show up.What's the best way to do it in 2010? Thanks in advance.
Fri, Mar 26, 2010 at 10:41:14 AM | Section through a family object and imported dwg file
The family has to be cuttable - look in the help for cuttable families.
Fri, Mar 26, 2010 at 10:56:48 AM | Section through a family object and imported dwg file
diesellam
It's cuttable.
But the elements beyond the section viewable range are also seen, how can I avoid that?
Fri, Mar 26, 2010 at 11:09:08 AM | Section through a family object and imported dwg file
Remember... if any part of a family is cut by the view plane, the family will show (if not cuttable).  So look at what is showing and see if that is your pronblem...  You can always hide in view.
Fri, Mar 26, 2010 at 11:43:42 AM | Section through a family object and imported dwg file
diesellam
How do you make the family cuttable?
Fri, Mar 26, 2010 at 11:51:56 AM | Section through a family object and imported dwg file
In the family editor, the family has to be set to a cuttable category under settings / categories.
Fri, Mar 26, 2010 at 12:41:24 PM | Section through a family object and imported dwg file
diesellam
Thanks.
What about the imported dwg file?  How can you make it cuttable?
I found some that I can do after doing the partial explode.  Some don't work at all no matter whether it's full / partial explode.  I got an error message saying the 3d data can't be exploded.  What's the alternative solution for this?
Section cut through the imported dwg file
Wed, Jun 26, 2013 at 4:00:40 PM
12
Imported object transparent faces
Tue, Mar 15, 2011 at 2:44:52 PM
solid object from 3D dwg
Thu, Apr 16, 2009 at 5:17:17 AM
Texture behaviour with new family from imported 3D object
Tue, Sep 27, 2016 at 6:58:11 AM
11
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Page generation time: 2.9205
