Forums >> General Discussion >> Revit Project Management >> Plotting Revit Projects in AutoCAD 101
Fri, Mar 26, 2010 at 2:48:57 AM | Plotting Revit Projects in AutoCAD 101
n7tran
Greetings RevitCity nation!
 I am a first year architecture student using revit for my studio design, loving it!
 Anyways, as I am a complete beginner, I am very new to plotting drawings in AutoCAD, using lineweights etc. This is even worse when it comes to exporting Revit files to dwg, which contain a set of predetermined line weights.
 My first project I plotted to pdf, it had no line weights, so I had to manually change line weights in Illustrator.
 Sorry to drag on, but my request is, I am looking for help, or please direct me to a site, where it can show me basics in plotting, assigning lineweights etc. I want my drawings to be effective as possible but also learn how to use CAD properly. I know this might be more of a CAD topic.
 Thanks so much
Fri, Mar 26, 2010 at 7:12:17 AM | Plotting Revit Projects in AutoCAD 101
Unlike CAD, Revit assigns lineweights by category.  We don't use layers or colors for that purpose but if we export a file to CAD, Revit uses a conversion file to determine what layers / colors to put the lines on in CAD.  You can read about exporting to CAD in your HELP.
You don't need to do what you are doing.  I don't know what PDF driver you are using because the PDF should show the lines correctly - that is with assigned widths.   What are you using?  Cute PDF is a fress program that works very well.
Plotting
Tue, Jun 23, 2009 at 5:51:33 PM
Over 150 very small projects
Fri, May 6, 2011 at 2:42:53 PM
Plotting
Mon, Oct 20, 2008 at 10:23:02 AM
Plotting/Printing in Revit.
Tue, Oct 26, 2004 at 9:01:58 AM
plotting exported files to match revit originals
Mon, Nov 7, 2011 at 2:30:30 PM
11
Page generation time: 2.6884
