Forums >> Revit Building >> Technical Support >> line to connect light switch to light fixture
Tue, Mar 9, 2004 at 9:03:13 AM | line to connect light switch to light fixture
dakota
does anyone know an easy way to draw a spline from a light switch to the fixture? can you create an electrical annotation subcategory for freehand lines? thanks.
Tue, Mar 9, 2004 at 12:19:07 PM | RE: line to connect light switch to light fixture
FMCustomDesign
I have created an Object Style for electical wires, and used Details Spline lines for my connections. It works well and you can set the line style and width for the line, as well at having control over visibility settings.
Wed, Mar 10, 2004 at 12:56:35 PM | RE: line to connect light switch to light fixture
dakota
do you think it's possible to create a flexible tail in the switch annotation symbol? maybe like a leader?
Opaque light fixture not emitting light
Wed, Dec 18, 2013 at 3:30:34 AM
Light fixture doesn't produce light
Sat, Jun 7, 2008 at 12:39:38 PM
Lighting fixture not showing ANY light
Fri, Apr 10, 2009 at 12:30:55 PM
trying to make custom light fixture w/ 2 light sources - need help
Mon, Jun 22, 2009 at 6:23:45 AM
Light Fixture Families
Fri, Nov 18, 2005 at 4:51:18 PM
Page generation time: 0.7325
