Forums >> Revit Building >> Technical Support >> Precast Concrete Shop Drawings
Wed, Mar 24, 2010 at 11:24:16 PM | Precast Concrete Shop Drawings
Sven
3.5 Stars: 3 Votes
I am wondering if anyone has detailed precast concrete panels in Revit (i.e workshop detail drawings)?
We use revit 2010 for our design services here, and typically use AutoCAD for shop detailing (using many blocks and automation already setup from years ago..).. but over the last year or so i've been pondering if we could be doing workshop detail drawings within Revit.
I have no issue modelling the detail of the project, with joints, cast in plates and ferrules, grout tubes etc all modelled appropriately. but how would we go about creating the individual shop details.
The only thought i've had to date is to create individual drawing sheets and individual callout views for each panel (which would therefore mean a tree of sheets up to 200 long).. we would then have to dimension each panel and its' fittings on each and every sheet -perhaps this can be automated somehow? i have attached an example shop drawing for reference
would love to know others thoughts on how this could be done?
Thu, Jul 11, 2013 at 1:46:01 AM | Precast Concrete Shop Drawings
huyxp
huyxp Avatar
Can you share project file in revit structure to me
Thanks I want It for study revit structure
Thanks you
my email: duchoatla@gmail.com
Sun, Jul 14, 2013 at 7:43:39 AM | Precast Concrete Shop Drawings
Pele
Pele Avatar
If nothing else you should offset your dimension lines from the drawing detail as it is hard to differentiate dimension lines & drawing lines.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net
Fri, Apr 10, 2020 at 2:08:54 AM | Precast Concrete Shop Drawings
ngocanh19
Hello Sven,
we done some big precast project  have 2000 pieces. and we have brick and some other finish sanblast....we do it by revit 100% erection and shop ticket by revit. can you email or skype me. i willl show me some this. please contract me skype: Nguyenngoccanh19 and email Nguyenngoccanh19@gmail.com.
Thanks
Precast Panel / Dado panel - Wall Schedule to issue drawings for shop detailing.
Tue, Sep 30, 2014 at 7:03:41 AM
Using Revit MEP to make ductwork shop drawings
Wed, Jun 15, 2011 at 9:52:02 PM
precast shop ticket Revit 2010
Fri, Jan 14, 2011 at 8:16:16 PM
Precast Concrete Panels
Fri, Mar 31, 2017 at 12:28:39 PM
13
Using Revit Structure to produce Steel Fabrication Drawings (shop drawings)
Sun, Feb 24, 2013 at 1:00:00 PM
Page generation time: 0.2242
