Forums >> Revit Building >> Technical Support >> Adding Trusses into Revit Project
Tue, Sep 20, 2005 at 3:36:48 PM | Adding Trusses into Revit Project
dmetcalf98
Hello, I downloaded a truss from this site called Gabled_Truss_2048.rfa and attempted to use in in my project. However after loading the truss, Neither the regular component nor Structureal component loading will show the truss for placement into the drawing. Can anyone adise me how to get it onto the model?
Wed, Sep 21, 2005 at 2:26:18 PM | RE: Adding Trusses into Revit Project
quiller
quiller Avatar
2.5 Stars: 3 Votes
Do this: Open the truss as if you were going to edit it, click on the truss and then click on Family Types, click new and it should currently say Type 1, change it to be Strucrural, click ok and save it under a different name. Load it back into your project and unders Structural/Brace you will find it.
Wed, Sep 21, 2005 at 3:02:13 PM | RE:
dmetcalf98
Quoting quiller - 2005-09-21 14:26:18
"Do this: Open the truss as if you were going to edit it, click on the truss and then click on Family Types, click new and it should currently say Type 1, change it to be Strucrural, click ok and save it under a different name. Load it back into your project and unders Structural/Brace you will find it."
Perfect, thank you!
adding trusses
Tue, Jun 29, 2010 at 7:14:26 AM
workflow for architectural building section showing roof trusses.
Wed, Jan 10, 2018 at 10:12:23 AM
Creating trusses
Thu, Dec 29, 2016 at 6:44:09 AM
Roof Trusses
Wed, Dec 23, 2009 at 6:56:52 AM
Trusses in Revit Architecture
Tue, May 20, 2014 at 3:53:36 PM
Page generation time: 2.3126
