Forums >> Revit Structure >> Technical Support >> Horizontal Bracing - getting it to look 'right'
Wed, Mar 24, 2010 at 2:37:02 AM | Horizontal Bracing - getting it to look 'right'
Tenacious
Using Revit Structure. Cannot get my horizontal bracing to look right. Inserting member as a beam with work plane set to my current roof. When I insert a brace member to columns/beam/truss intersection crazy cut backs occur to the orginal col/beam/truss members i.e. suddenly my beam projects 200mm past the gridline intersection. When I remove the horizontal brace member my column/beam intersections go back to how they are supposed to look.
 Anyway of changing your beam member so it doesn't apply cuts etc to existing members on in your model.
Thu, Apr 1, 2010 at 5:10:01 PM | Horizontal Bracing - getting it to look 'right'
emgeeo
3.5 Stars: 7 Votes
Have you tried to model the brace with the brace tool/command?
Vertical and horizontal bracing connections
Mon, Jun 24, 2013 at 7:18:38 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Turning 'Ortho' Off
Tue, Jan 12, 2016 at 2:07:01 PM
4' - 4' Accostical Ceiling Tile - Joining Soffit horizontal wall with vetical
Thu, May 14, 2009 at 12:50:09 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Page generation time: 0.9771
