Forums >> Revit Building >> Technical Support >> custom riser height for staircase
Wed, Mar 24, 2010 at 12:08:35 AM | custom riser height for staircase
rlaw
HI everyone,
I am new to this website and the program itself. I hope someone can help me on the question. I built the staircase for the house that I am working on. Due to the headroom issue, the riser has to be 7 -7/8" tall. I went to stair property to set up the max and min for the riser and tread but it still didn't change to exact 7 7/8". Also, I moved the floor up and down and finally changed to 7 7/8". However, I know I can fit a staircase with 7 7/8" and solve the headroom issue. Does anyone know how to set the exact hight for my riser? If there is no way I can do the direct change. What else you would recommend ?
 Thanks for your hope
Regards
Rico
Custom Stair Riser Height
Wed, May 27, 2009 at 10:00:38 AM
Staircase Sketching - Riser count not reducing in number
Thu, Jul 11, 2013 at 5:40:37 AM
Staircase railing problem
Fri, Jun 19, 2009 at 9:25:46 AM
Staircase - Issues with Plan Graphics/Representation.
Sat, Sep 18, 2010 at 11:54:22 PM
How to create Folded Plate Staircase
Wed, Dec 17, 2008 at 4:09:59 PM
Page generation time: 0.4293
