10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Elevation Line Extensions
2 Posts No Rating |
How can I manipulate my Elevation lines in my Exterior Elevation View so that the line extension ends at the object and does not extend through my building, without inadvertantlly changing the extents of my level?
1 Posts No Rating |
I have the same request. Anybody have a way to show the levels tags, but not have the datum line run through the elevation drawing?
You can drag the ends of your elevation lines to wherever you would like them to be. You can click the 3D that shows up when you select the level to turn it into 2D so that it changes ONLY in the view that you are in.
Handrail Extensions in 2013 - Where is it? |
Sun, Jul 12, 2015 at 11:54:18 PM
Revit Extensions Tuitorial |
Wed, Oct 14, 2009 at 8:58:21 PM
Stair Handrail Extensions |
Fri, Apr 11, 2008 at 10:48:31 AM
wall extensions not working |
Wed, Feb 17, 2010 at 6:16:11 PM
14
How to not have elevation line crossing the model? (level heads on both sides) |
Wed, Aug 6, 2014 at 1:37:02 AM
