Forums >> Revit Building >> Technical Support >> Revit column schedule with split models...
Tue, Mar 23, 2010 at 3:59:21 PM | Revit column schedule with split models...
acastillo84
I’m working on a 13 story court house building in Revit that we ended up splitting the model and was wondering if anybody knew of a way to make the column schedule work? Or how would I go by using the column schedule? The way we ended up splitting the model is one for the lower portion, upper portion, grids and levels, and the master model which we import all 3 models. any suggestions would be appreciated.
thanks.
Fri, Apr 2, 2010 at 6:42:11 PM | Revit column schedule with split models...
cobblea
First step would be to open up your master model that contains all of your columns (linked in or native or both), and in the properties of your schedule view, look under the first button that says "Fields".  In that dialog, there is a checkbox at the bottom left that says "Include elements in linked file".
Try checking that box, and see how that works.  You should see all of your columns in the schedule now  (I think). Good luck-- sounds like a big project!
Concrete Columns shown split in Column Schedule
Wed, Aug 19, 2020 at 8:16:11 AM
spliting models
Fri, Dec 10, 2010 at 9:37:48 AM
Eleminate Column Split in Schedules
Thu, Jul 5, 2012 at 3:05:10 PM
Titles on split Schedules
Thu, Jun 13, 2013 at 1:48:24 PM
Column Schedule
Mon, Apr 21, 2008 at 7:35:29 AM
Page generation time: 3.9335
