Forums >> Revit Building >> Technical Support >> Floorplan visibility in the 3D view?
Tue, Mar 23, 2010 at 1:23:00 PM | Floorplan visibility in the 3D view?
ECdes
Hello.  I am new to Revit and am very appreciative of this forum.  My issue is that I am not able to see the floorplan underlay when I go to the 3d view.  The plan is visible for modeling in 2D, but when I switch to 3D, the plan underlay disappears.  Do I need to have something turned on to view plan in 3d? Do I need to select something when I import the CAD plans? Thank you for your help.
ECdes
Tue, Mar 23, 2010 at 1:40:51 PM | Floorplan visibility in the 3D view?
4 Stars: 205 Votes
Are you talking about a 2D plan in CAD you just import to your project and you only can see that plan in one view? if so, when you insert the cad file, be sure you don't have the "Current View Only" ON
Tue, Mar 23, 2010 at 2:09:06 PM | Floorplan visibility in the 3D view?
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
There is no underlay in 3D views properties, this only applies in floor plan views. If I understood your question correctly you should go to the following.... Visibility/Graphics Overrides for 3D views (VV)â–ºImported Categories.... and turn on your plan that you imported from CAD.
 "If you tell the truth, you don't have to remember anything"
view range for floorplan views
Tue, Sep 27, 2005 at 2:41:03 PM
Make annotation on wall-mounted family show on floorplan
Wed, Nov 12, 2008 at 1:41:40 PM
Wrong level view of window familly in floorplan
Mon, Mar 12, 2012 at 4:45:10 AM
11
Technical assistance floor plan details missing from view but not sheet
Mon, Mar 6, 2017 at 9:28:02 PM
Tiled View changing
Fri, Apr 17, 2015 at 10:20:39 PM
Page generation time: 1.5123
