Forums >> Revit Systems >> Technical Support >> "System Color Schemes" not regular color schemes in Elevation or Section views
Mon, Mar 22, 2010 at 3:57:11 PM | "System Color Schemes" not regular color schemes in Elevation or Section views
Burly
Burly Avatar
I have an HVAC routing layout that shows supply and return in a plan view. The Supply is in Blue and the Return is in Red and there is a Legend called "Duct Routing Color" that shows Blue and Red.  In addition there is also a basic "Color Scheme" legend that shows the HVAC Zones. The aones are also shown in colors. So (1) legend for Duct colors and (1) legend for Zone colors. The colors of the ducts and legends in the plan view all display exactly the way I want.
I'm trying to get the Duct colors and Duct color legend (also known as "System Color Schemes"Winking  to show up in an elevation view exactly the way i have it in the plan view i just described.
I'm able to get the Zones legend and Zone color scheme to appear in the elevation exactly as i made in the plan view, but not the Duct colors legend and color scheme.
When you click "view properties" on the plan view it lists "System Color Schemes" under "Graphics", but do the same on the elevation view and it doesn't appear. When I try to insert a new legend it just duplicates the HVAC Zones legend that is already present in the elevation view.
 Much thanks for any suggestions
 -Kevin
Mon, Mar 22, 2010 at 4:10:56 PM | "System Color Schemes" not regular color schemes in Elevation or Section views
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Search Pipe Color in the forums GMMcCrossin asked a similar question and Brettggodchild had a very good answer. This will probably help
Mon, Mar 22, 2010 at 4:23:37 PM | "System Color Schemes" not regular color schemes in Elevation or Section views
Burly
Burly Avatar
Thanks for the help.
Yeah, the thread didn't quite seem to address what I was looking for.
I am, by the way, using a filter system for the Supply and Return and have the Ducts and every catactory relative to Ducts that I want to show up as Red and Blue set in a filter. All ducts show up as red and blue in both the plan and elevation views - looks good.
The issue is the legend; "System Color Legend" vs  "Color Legend" as can be seen in the "view properties." in the elevation view i can't simply make a new color legend for the ducts. "Duct Legend" button is greyed out under the analyze tab and "System Color Scheme" doesn't show up under "view properties" for the elevation view.
If pictures help i can take a few.
Thanks
Mon, Mar 22, 2010 at 6:00:00 PM | "System Color Schemes" not regular color schemes in Elevation or Section views
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Not system color schemes, as I stated exactly. Other wise you will not find an answer I know I been down this road before
area color schemes
Fri, Jan 27, 2012 at 12:07:13 PM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:35 PM
Color Schemes
Thu, May 23, 2013 at 12:35:43 PM
Color Schemes
Wed, Jun 3, 2015 at 3:15:18 PM
Color Schemes - Revit 2009
Fri, May 8, 2009 at 12:02:04 PM
Page generation time: 1.0203
