Forums >> Revit Building >> Technical Support >> Curved Dimensions Revit Architecture 2010
Mon, Mar 22, 2010 at 8:02:42 AM | Curved Dimensions Revit Architecture 2010
jware
Please Help...!
 I have a building that is set out to a radial curve with a centre point. However I have come to dimension the grid lines but can only seem to place radial/angled dimensions when I would like mm. Although I can override the text value, this will not be assosiated. Does anyone have a solution?
 I thank you in advance
Mon, Mar 22, 2010 at 8:07:25 AM | Curved Dimensions Revit Architecture 2010
Are you saying you want the length of an arc section - not the chord length?  ...
Mon, Mar 22, 2010 at 10:19:28 AM | Curved Dimensions Revit Architecture 2010
jware
That is correct Yes.
 I am after the length of an arc between two points.
Revit Architecture 2010 Service Pack 2
Sun, Oct 18, 2009 at 11:19:49 AM
14
Tag dimensions to reference plane in 2010
Wed, Jan 6, 2010 at 1:41:42 PM
Create in-fill walls under spiral stairs - Revit Architecture 2013 specific
Thu, Jul 7, 2016 at 10:50:48 AM
???????????????Curved Curtain Wall Dimensions???????????????????
Fri, Nov 7, 2008 at 4:23:29 PM
Curved height level in revit architecture 2014
Tue, Jun 7, 2016 at 7:03:54 AM
Page generation time: 2.5656
