Forums >> Revit Building >> Technical Support >> structural wall VS structural columns
Fri, Mar 19, 2010 at 1:14:49 PM | structural wall VS structural columns
leotrans
I want to use structural walls, because they are more flexible to be modified instead of structural columns.
2 issues :
1- I do not want them to trim with other walls - just act as columns
2- when exporting in dwg I want them to be the same layer with columns (right now they export same layer with other walls)
anybody has any suggestions
thanks
Fri, Mar 19, 2010 at 2:36:37 PM | structural wall VS structural columns
TKennedy
4 Stars: 8 Votes
First, how is a wall more flexible than a column? If you need a column in your model, you should be using a column, not a wall.
To make a wall not join other walls, right click on the grips at the wall and select disallow join.
You can change what layers are used for each category when exporting. I forget how to get there though, it's been too long since I've exported to a dwg. Search your help, it will be there.
Fri, Mar 19, 2010 at 3:24:39 PM | structural wall VS structural columns
leotrans
I need a wall, for example when a structural wall is wrapping around a cast in place concrete staircase.
I cannot use a single column for that.
 If I place a structural wall in this case, it trims with other "normal" walls around it
this is what I would like to avoid.
thanks
Tue, Apr 26, 2016 at 3:49:39 PM | structural wall VS structural columns
sllana
5 Stars: 2 Votes
If anyone still conserns about this, my solution is to make a column family that changes its parameters
(length and width) by INSTANCE
Edited on: Tue, Apr 26, 2016 at 3:50:45 PM
Structural columns
Mon, Jan 16, 2012 at 8:37:32 AM
Structural Columns not cutting walls
Mon, Jan 4, 2016 at 4:13:25 PM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
Structural graphical columns schedules
Mon, Apr 25, 2016 at 3:19:18 PM
Wall wraping in windows and structural columns
Mon, Feb 2, 2015 at 11:58:44 PM
Page generation time: 0.6850
