25 Users Online (23 Members):
Forums >> Revit Structure >> Technical Support >> stud wall w brick
140 Posts No Rating |
I have not done much with complicated walls and maybe a stacked wall is best for this option, but I am hoping for some general ideas. How can I get somethin like repeating 2d detailes in side the family to attahed to the bottom and top of a wall(system family)...is that possible. That way I could have for example: metal stud punched in the wall that are just lines in a fine view section cut. Or have brick profiles repeated up the exterior surface? This is pretty complicated..any pointers in the right direction would be appreciated. Greg
The answer is you don't. Revit's walls show the skin with a surface pattern in non-rendered views or a material pattern in rendered views and in section or plan will show the layers of wall with material indications but that's all. When you cut a detailed section, you add detail components as you need to the model section.
I fugured as much. Thanks for the fast reply; it will keep me from wasting my time.
Window in brick/stud wall |
Fri, May 26, 2006 at 2:43:48 AM
Window Placement in Stud/Brick Veneer Wall [ 1 2 ] |
Wed, Feb 4, 2009 at 11:22:19 AM
15
RAC 2012: Window Trim Reveal in brick/Stud Wall |
Mon, Jul 2, 2012 at 2:08:10 PM
modifying generic 8"inch wall to brick over stud |
Wed, Nov 1, 2006 at 9:05:58 AM
Which Template does have Brick and CMU over MTL Stud. |
Fri, Jul 15, 2011 at 3:38:08 AM
