Forums >> Revit Building >> Technical Support >> Logo in titleblock won't print with HP printer
Wed, Mar 17, 2010 at 4:42:51 PM | Logo in titleblock won't print with HP printer
alex8605
The logo on my titleblock won't print with my HP Designjet 500 printer.  It will print on a small laser printer and it shows up when I send it to PDF Creator.  I have tried raster/vector changes, and various different settings in the HP print setup.  I can however insert the logo, which is a jpg file, directly onto a sheet.  This is a work around but for each sheet I have to insert the logo, size it, and place it precisely.  I figure it must be a problem with the printer, but since this is a common printer I thought others may have had this problem.
Thu, Mar 18, 2010 at 11:13:11 PM | Logo in titleblock won't print with HP printer
Juzza
Juzza Avatar
I've had problems with using JPEG Logos before, when printing to PDF using a JPEG image our Logo would always look 'hairy', Although I've never had them disappear... I was able to reproduce our logo using filled regions with text over & that solved our problems, if it's possible with yours this could be worth a try??
Image Missing From Titleblock Once Printed
Wed, Apr 11, 2012 at 8:57:20 PM
Logo on a Titleblock showing up in negative
Wed, Oct 31, 2012 at 7:49:50 AM
Titleblock parameters / labels
Tue, Apr 7, 2009 at 12:41:34 PM
jpg image won't show when I print titleblock
Fri, Feb 6, 2009 at 2:51:53 PM
Printing Images on my TitleBlock..???
Wed, Feb 16, 2011 at 10:24:54 AM
Page generation time: 0.8742
