Forums >> Community >> Newbies >> Several buildings in the same project
Wed, Mar 17, 2010 at 1:39:03 AM | Several buildings in the same project
BizkiD
Hello
i was wandering how to properly do several buildings on the same site ( house, seperate garage and other minor building) ......do i need to make seperate file for each building and the import into one site or in one file and some how rotate true or project north each time i edit one of the apropriate buildings.......pls help, cause i'm really lost here ppl....what's your method or workflow  of going around this problem?
Wed, Mar 17, 2010 at 7:13:59 AM | Several buildings in the same project
With as small a project as this is, you should be able to do it in one file - that is if you can place all the buildings and not want to move them later.  Don't worry about the differential angle between buildings.  You can rotate the view for each model plan so that it is still square with the sheet and to work on it.
Thu, Mar 18, 2010 at 1:25:55 AM | Several buildings in the same project
BizkiD
actualy i've been searching the web for this answer and cam accros this technique similar to dwg xref.....one file for each building and one file for the site.....link em together with shared coordinates.....and vualah .....started to do just that, it seems to work just fine FOR NOW.....we'll c where we end up at
Thu, Mar 18, 2010 at 6:56:21 AM | Several buildings in the same project
Yes - this is called file linking and you can do that.  You don't have to search the net about that.  There is a lot of information on how to do that in your HELP.
I recommended one file because your project will be so small.
Thu, Mar 18, 2010 at 4:29:24 PM | Several buildings in the same project
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Agreed.  Do this in one project.  You might want to enable worksharing so that you can effectively turn off the buildings you do not wish to see or work on.
Fri, Mar 19, 2010 at 1:34:55 AM | Several buildings in the same project
BizkiD
mmmkey.....one problem thoe......how do i turn of and on seperate buildings? do i just duplicate windows for instance of the first plan and just crop the views on the buildings that i want to c? or there's some sort of other way?because i think i will encaunter a problem when i face elevations....where i have too much levels in my smaller buildings elevation plan views.......also....i already made my building in seperate files......how do i put then into my original file along with all my grids and detailing and levels?
Fri, Mar 19, 2010 at 7:51:48 AM | Several buildings in the same project
You can link your projects inserting them into one main project in the proper location, rotation and elevation then bind them in.  They will become a group which you can then ungroup.  You can read about this in your HELP.  You should experiment with this in copied files and see what happens.
You can do several things regarding views.  You can have your seperate buildings in seperate worksets and just turn that workset off where appropriate or as you already know, just place your view callouts and crop regions where they will show only what you want.
Fri, Mar 19, 2010 at 2:25:20 PM | Several buildings in the same project
itsmyalterego
4 Stars: 16 Votes
Once you get your buildings into one file, you can then simply drag-select an entire building, right click, and select "move to workset:"
Then, under the collaborate tab, you have a workset dialog box that allows you to manage the active workset, gray out or hide innactive worksets.
Fri, Mar 19, 2010 at 11:09:19 PM | Several buildings in the same project
BizkiD
thank you very much....i haven't tried the workset thing before, this will be my debut.....will c what happen
LINKING MULTIPLE BUILDINGS INTO ONE PROJECT
Wed, Nov 29, 2006 at 8:04:32 PM
Multiple buildings on one site
Wed, Feb 4, 2009 at 6:52:04 PM
One Site. Several Buildings
Fri, May 23, 2008 at 6:45:09 AM
project set up
Sun, May 11, 2008 at 11:49:21 AM
Multiple Building Project. Need advice.
Tue, Oct 13, 2009 at 10:28:32 AM
Page generation time: 0.7950
