Forums >> Revit Systems >> Technical Support >> Create a sheet
Tue, Mar 16, 2010 at 2:32:33 PM | Create a sheet
Kbtrpnis
I created a sheet with 2 floorplans and 3 elevation views, north, east and west. But if I select the south view I dont see the created building. How's this possible, or what i'm doing wrong?
Tue, Mar 16, 2010 at 3:04:49 PM | Create a sheet
Click on the callout for the elevation in your floor plan and you will see where the cut line is and the depth of the elevation.  You will need to adjust these so that your building is in the view.
Tue, Mar 16, 2010 at 3:28:45 PM | Create a sheet
Kbtrpnis
Thanx!
Sheet
Fri, Apr 22, 2005 at 1:01:52 PM
Create Sheet notes symbol to add to sheet plan
Tue, Apr 14, 2009 at 4:07:25 PM
sheet __ of 20
Fri, Feb 22, 2019 at 8:52:56 AM
Multiple independent sheet index for cover sheet
Tue, Feb 4, 2014 at 8:28:13 AM
Sheet Template - editable text
Thu, Mar 5, 2009 at 3:40:42 AM
Page generation time: 7.8324
