Forums >> Revit Building >> Technical Support >> AUTOCAD LINKED FILE QUESTION
Tue, Mar 16, 2010 at 10:27:52 AM | AUTOCAD LINKED FILE QUESTION
CKorleski
GOODMORNING ALL, I HAVE A MEP PROPOSAL THAT I AM WORKING ON, AND TO SAVE TIME I AM GOING TO LINK AN AUTOCAD DWG. IN TO MY MODEL TO PROVIDE A BACKGROUND.  THE PROBLEM I AM HAVING IS THE LINK WILL ONLY SHOW UP IN A SINGLE PLAN VIEW.  IS THERE A WAY TO HAVE THE CAD LINK VISIBLE IN ALL PLAN VIEWS, AND STILL MAINTAIN THE VISIBLITY DEPTH SET UP FOR A PERTICULAR PLAN.  OR DO I HAVE TO IMPORT THE LINK INTO EVERY LEVEL????  THANKS
Thu, Mar 18, 2010 at 3:50:30 PM | AUTOCAD LINKED FILE QUESTION
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
I'm unsure what you mean by the visibility depth -- in my experience, it's the default for imported autocad files to be visible on all floors.  You could check your visibility settings, and see if imported families are turned off in some.  Or, if I am mistaken, (only worked on projects with three floors)  You could created a level for your imported autocad file, and set this as your underlay for your views, if you aren't actively using other floors as underlays.
Linked AutoCAD file printing grey
Mon, Jul 26, 2010 at 10:07:25 PM
Invalid Dimension to linked AutoCAD file.
Tue, Mar 13, 2007 at 11:24:22 AM
Problem with autocad linked file
Fri, Mar 2, 2018 at 12:24:23 PM
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
exporting to autocad
Fri, Aug 31, 2012 at 7:35:41 AM
Page generation time: 1.1783
