Forums >> Revit Building >> Technical Support >> Floor Plan zoom question
Mon, Mar 15, 2010 at 11:32:18 AM | Floor Plan zoom question
OPIE
We are using RA 2009
One of our partners has a project with multiple levels, on the sheet the second floor plan shows up as it should
When he goes to the second floor plan view to make changes all he can see is one vertical line (the crop region)
I have zoomed in on it until i can adjust the left and right but the top and bottom are WAY up/down
I have scrolled up and down and have not found the modelin the floor plan view just the left and right crop region boundries
Anyone have any idea as to what would cause the crop region to zoom out to infinity and why the floor plan shows up on the sheet but not in the floor plan view itself?
Mon, Mar 15, 2010 at 11:46:36 AM | Floor Plan zoom question
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Do you have any reference survey data loaded? Some times the surveyor's reference points are so remote and Revit wants to see all when loading that it will zoom out. If you have some reference data loaded remove it.
Strangest Revit Floor Plan / Level Problem - Not a newbie question
Wed, Oct 4, 2017 at 1:59:11 PM
(Dumb question) Can't see first floor when in second floor view [Revit 2015]
Thu, Jul 16, 2015 at 6:11:13 PM
Floor Patterns only showing up when i zoom in
Thu, Nov 14, 2013 at 3:36:50 PM
Can't Zoom into Inserted Image
Thu, Jul 1, 2010 at 5:06:11 AM
Zoom and text - any way to tell which zoom level you are working in?
Wed, Jan 7, 2015 at 9:30:59 AM
Page generation time: 0.6685
