Forums >> Revit Building >> Technical Support >> Removing multiple curtain wall grid segments
Sat, Mar 13, 2010 at 7:56:16 AM | Removing multiple curtain wall grid segments
Altruant
I am trying to remove a large number of grid segments but don't know how to do it quickly and efficiently as i keep doing each one separately.
 As there is a very high amount of segments, i'm hoping there is a quicker way.
Any help would be appreciated
 revit 09 +10
Sat, Mar 13, 2010 at 8:11:53 AM | Removing multiple curtain wall grid segments
4 Stars: 205 Votes
There isn't a quickly way to do that, just pick and "Add/remove...".... Sorry mate...
Sat, Mar 13, 2010 at 8:16:49 AM | Removing multiple curtain wall grid segments
Altruant
Certainly they need to change that in the new revit - this is just painful doing it. Spent the last 2 n half hours removing segments and about half way through.
Watching 6 nations while doing it now. Ha ha
Mon, Mar 15, 2010 at 1:20:18 AM | Removing multiple curtain wall grid segments
Erik
I certainly also would like a way of deleting multiple curtain wall grid segments.  Mine are usually not many
Have you tried to go the other way; remove all (change the curtain wall family) and then create the once you want ?
I guess it depends on waht is the quickest
Mon, Jun 13, 2016 at 9:53:15 PM | Removing multiple curtain wall grid segments
rinzi
I had the same issue but I found a solution to easily delete single segments of a curtian grid system.
1. Go to Architecture Tab
2. Select Curtian Grid
3. Modify/Place curtian grid will pop up.
4. Select the cut tool, that splits in two.
5. If you want to cut Horizontal segment, cut at a vertical grid line.
6. Then it will show segments as its own piece.
7. Select segment and press delete. (I prefer delete on keyboard for best efficiency)
Hope this helps!
Curtain Grid Removing Segments
Mon, Jul 2, 2007 at 1:05:12 PM
Removing Segments from a wall sweep
Mon, Jan 16, 2012 at 11:25:12 AM
Revit 2013 Curtain Wall Variable Grid Spacing
Thu, Jul 18, 2013 at 2:10:54 AM
removing grid lines from curtain
Thu, Oct 11, 2012 at 11:59:27 AM
Curtain Wall Grid Angle
Tue, Feb 15, 2011 at 2:42:32 PM
Page generation time: 0.8855
