Forums >> Revit Building >> Technical Support >> Tag Types
Thu, Mar 11, 2010 at 5:22:56 PM | Tag Types
SteveB
3.5 Stars: 5 Votes
when i try to tag an object, the message comes up:  "you have not loaded a tag for this type of object.  would you like to load the tag now?".  Why yes, helpful Revit Note Suggester, I would.  there ensues endless rumaging around looking for the correct "type" of tag.  Is there a way to view the objects attributes and see what "type" of tag is needed?
Thu, Mar 11, 2010 at 6:01:02 PM | Tag Types
TomDorner
4.5 Stars: 25 Votes
Tags are by category in Revit.  Look at the category list and you can decide what tags you need.  The best approach is to pre-load the tags into your template so they are present when you go to tag an object category.
Tom
door tag types
Thu, Sep 3, 2015 at 6:39:54 PM
updating/changing elevation tag types
Wed, Mar 19, 2008 at 9:49:46 AM
Tag all not tagged
Fri, Aug 11, 2006 at 1:27:50 PM
Electric Door TaG
Tue, Feb 11, 2014 at 5:28:23 AM
Change unit types for property area tag
Tue, Jun 2, 2009 at 4:49:52 PM
Page generation time: 0.2147
