Forums >> Revit Building >> Technical Support >> Elevation/Creating Hidden lines
Thu, Mar 11, 2010 at 4:24:43 PM | Elevation/Creating Hidden lines
Arch145763
I need the foundation that is below grade (in my elevations) to show up as hidden lines, does anyone know how to do this?
Fri, Mar 12, 2010 at 4:02:27 AM | Elevation/Creating Hidden lines
4 Stars: 205 Votes
Use the "Show Hidden lines" tool or use the "Linework" tool....
Fri, Mar 12, 2010 at 12:18:34 PM | Elevation/Creating Hidden lines
TKennedy
4 Stars: 8 Votes
You could also create a filter and use V/G to control them a little more automatically.
Fri, Mar 12, 2010 at 12:43:17 PM | Elevation/Creating Hidden lines
I don't believe the filter will work.  Filters are used to control how something is shown...if it is shown.  The problem is the foundations are hidden by the ground.  Use Typhoons method.
Hidden lines in elevations
Mon, Sep 10, 2007 at 9:43:06 AM
hidden lines below grade
Mon, Oct 1, 2007 at 2:19:41 PM
Show Hidden Lines Creating Double Lines
Mon, Sep 23, 2013 at 11:55:16 AM
Lines hidden with the line tool - how to see them again?
Thu, Dec 13, 2007 at 12:13:02 PM
Show Hidden Lines Tool and Detail Elements
Fri, Nov 22, 2013 at 8:48:50 AM
Page generation time: 0.5690
