Forums >> Revit Building >> Technical Support >> Curved monolithic stair problem
Thu, Mar 11, 2010 at 1:32:08 PM | Curved monolithic stair problem
edelong
I'm trying to create a monolithic stair that follows a gentle curve.  When creating the stair, I choose "run", then draw the arc from center for the required number of risers.  When I click "finish stair", no errors show up...and no stair shows up either!  Just the handrails.  I tried splitting the boundary at each riser, but it gave me the "no more than two boundries" error.  Any ideas what I'm doing wrong?
Thu, Mar 11, 2010 at 1:33:13 PM | Curved monolithic stair problem
edelong
Sorry...using RA 2010.  And I'm sure that the stair visibility is on.
Thu, Mar 11, 2010 at 1:38:50 PM | Curved monolithic stair problem
edelong
Thu, Mar 11, 2010 at 2:03:10 PM | Curved monolithic stair problem
4 Stars: 205 Votes
Hummm, are you sure you have in VG the Stairs ON?
Thu, Mar 11, 2010 at 2:12:51 PM | Curved monolithic stair problem
edelong
HAHA...I was just going to try and draw a monolithic stair anywhere with a radius to see if it would work, and I got one of those all-to-familiar flash crashes of Revit 2010.  You know...the one where one second the program is there, the next its gone without any chance to save anything?  I'm REALLY missing RA 2009.  And so is the last 45 minutes or so of work.  Dammit.
Anyway...yes, I WAS sure that visibility was on.  It didn't show up in plan or 3D view, while other linear stairs did.  Maybe its just another bug.  A "7" riser 11" tread" stair works just fine on the same radius.  I guess I should just get used to thing not working for unexplained reasons in RA 2010.  <sigh>
Thu, Mar 11, 2010 at 2:16:51 PM | Curved monolithic stair problem
4 Stars: 205 Votes
Did you install the Web updates for Revit 2010?
Thu, Mar 11, 2010 at 2:33:31 PM | Curved monolithic stair problem
edelong
Yeah...installed those when our IT guy first installed it a couple months ago.  Figured out they existed because after opting not to be reminded about the tutorial, it would crash whenever I tried to open a drawing.  I have the required 4 GB of memory as well.  I'll check and see if there's an ever newer update...
I just don't understand why every program is going to this Vista "panel" configuration.  I hated it when MS Office did it, and I now hate that Revit did it.  I miss my toolbars stacked on the side.  Ah well...adapt and overcome, I guess.
Ye Olde Curved Monolithic Stair
Wed, May 29, 2013 at 8:31:14 AM
Monolithic stair PROBLEM
Sat, Feb 9, 2013 at 8:14:32 AM
CAN'T MAKE MONOLITHIC STAIR
Fri, Feb 5, 2016 at 10:16:18 AM
13
Monolithic stair - large construction height error
Thu, Oct 13, 2011 at 12:10:33 PM
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:24 AM
Page generation time: 2.6886
