Forums >> Revit Structure >> Technical Support >> Family Creation - Array number variable
Thu, Mar 11, 2010 at 11:30:37 AM | Family Creation - Array number variable
gregroberson
gregroberson Avatar
In a family, you can array items.  Does anyone know if it is possible to assign the "number" of arrayed items to a variable.
For example, adding a repeating detail to a member..based on its length parameter.  Or to have voids (or model lines = profiles) arrayed along a members length as in light gage punches in a channel?
Or soes anyone have any tips?
Thu, Mar 11, 2010 at 1:52:53 PM | Family Creation - Array number variable
TKennedy
4 Stars: 8 Votes
When you select one of the objects in an array a line pops up along the array. It has the number of items arrayed, and short leaders to each item. Pick that line and on the options bar there will be a drop down where you can assign a parameter, or add a new parameter.
Fri, Mar 12, 2010 at 12:48:45 PM | Family Creation - Array number variable
gregroberson
gregroberson Avatar
Fantastic.  Thanks for replying, I am embarrassed I have not checked sooner.
Fri, Mar 12, 2010 at 1:15:31 PM | Family Creation - Array number variable
gregroberson
gregroberson Avatar
Worked Perfect.  Thanks again.
SAMPLE FAMILY REQUIRED EG:CABINET WITH VARIABLE NUMBER OF DOORS
Mon, Sep 3, 2007 at 9:31:07 PM
array
Mon, Feb 26, 2007 at 3:09:19 PM
ARRAY INSIDE A FAMILY
Fri, Oct 12, 2007 at 12:41:17 AM
Variable number of mullions
Mon, Nov 21, 2005 at 2:39:22 PM
Family w/ Array Formula
Fri, Mar 23, 2007 at 9:29:37 AM
Page generation time: 0.7509
