20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Structural framing
33 Posts No Rating |
I've used LVL's for rafters and want to cut the tails down to 100mm from 240mm.
It dosen't work with voids. so do I have to use extrusions for rafters etc. in order to be able to modify shapes or is there another way.
Best way would be to create a family for the beam.
In the family add an adjustable void to give the appropriate tail.... You could even set it up with a yes/no to set whether it has a cut tail or not.
Thanks Mr Spot,
Can you suggest any related tutorials
structural framing family cut pattern interacting with wall in section 2017 |
Wed, Sep 5, 2018 at 12:52:56 AM
Structural Framing Plans/Callout Beam Sizes |
Wed, Feb 22, 2006 at 5:49:10 PM
Structural framing tag |
Mon, Apr 5, 2021 at 1:29:32 PM
Structural Framing Tag |
Tue, Feb 26, 2008 at 10:27:24 AM
structural framing vs scheduling (volume report) |
Fri, Feb 25, 2005 at 11:15:12 AM
