24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Revit View Title with buble on right side
2 Posts No Rating |
I'm trying to create a view title similar to the attached file. Basically what I want is the title and scale at the left of the view, and the drawing/sheet reference buble at the right. So far all I have been able to do is create the view title with a fixed lenght. Has anyone had any success with this? Thanks
That is all you can do. We created a couple of different lengths. No way to adjust bubble on right titles.
2 Posts No Rating |
Thanks WWHub, While there may be no way for the end user to achieve this now, I don't beleive that its imposible with some sort of programming change/update. It seems that it should stand to reason that if they can attach the start point to the left side of the view, that they should be able to make it so that the bubble can be attached to the right side. They have done it for the line, which I know is somehow done as a system variable, so I see no reason to not be able to do it with rest. Guess I'll have to send it direct to AutoDesk and see what happens.....................
Go ahead and ask AutoDESK... the more people ask for this, the quicker they may respond ... but believe me, you are not the first. :->
View Title with reference on right side |
Thu, Oct 3, 2013 at 3:12:17 PM
View Title Anchored at the Right Side |
Wed, Jan 31, 2024 at 2:27:23 AM
Custom View Title |
Thu, Mar 14, 2013 at 8:06:51 AM
Modify View Title |
Wed, Jun 11, 2014 at 7:37:29 AM
11
View Title for Legends |
Fri, May 6, 2016 at 4:27:58 PM
