Forums >> Revit Building >> Technical Support >> Revit 2010 to 3ds Max Design 2010 vray 1.5 SP4
Wed, Mar 10, 2010 at 5:18:39 AM | Revit 2010 to 3ds Max Design 2010 vray 1.5 SP4
rollie
rollie Avatar
3 Stars: 1 Votes
Hi..everyone...is it true that u dont need to change the materials from revit models u imported into 3ds max via fbx when ur using vray 1.5 sp4? if this is true..does any1 tried it already? coz it'll be much easier if that is true..and btw, im havin a problem with replacing revit material to vray material..does anyone know how to? or has a link of tutorials on replacing revit promaterials to vray material..thanks alot.more power.
Fri, Sep 10, 2010 at 1:59:46 PM | Revit 2010 to 3ds Max Design 2010 vray 1.5 SP4
jeneish
you can easily export from revit 2010& 2011 to max. all you have to do in revit is export it as fbx. and open 3dsmax and import the file and render in metal ray.with photometric setting.work gr8
3ds Max-3ds Max Design 2010
Thu, Apr 16, 2009 at 12:15:17 PM
problems inporting from revit 2010 to 3ds max 2010
Sun, Mar 13, 2011 at 6:17:59 AM
.ies files from Revit export to 3Ds Max rotate incorrectly
Wed, Aug 19, 2009 at 2:06:14 PM
Revit 2010 to 3ds Max 2010 Problem
Thu, Jul 30, 2009 at 9:31:25 AM
Tue, Aug 11, 2009 at 9:40:37 AM
Page generation time: 2.9620
