29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Vanishing Title Blocks
18 Posts No Rating |
So something happened in the project where every single sheet titleblock (all the plan, elevations, section etc. name tags) Just disappeared, when I place a new view into a sheet, it doesnt create a drawing title. My guess is some visibility setting issue, but I cant seem to find what is causing this problem. Anyone that could steer me in the correct direction? Thanks
A view title for a sheet is a family that is definable or re-definable as it looks in your case. Someone must have changed your default view title to none ... but you can redefine it. Do a search of your HELP using "view title" and you will find topics on how to modify your view titles.
Yeah, by mistake the default type was changed to not display the titles. Thanks, crisis averted!
Delete or Purge out Title Blocks? |
Wed, Nov 26, 2008 at 5:06:00 PM
Customize new Title Blocks |
Mon, Sep 21, 2009 at 2:55:19 PM
Sheets Title Blocks |
Mon, Jul 6, 2015 at 2:30:16 PM
Title blocks |
Mon, May 11, 2009 at 2:53:44 PM
creating custom title blocks |
Tue, May 22, 2007 at 2:29:40 PM
