Forums >> Revit Building >> Technical Support >> lineweight by material
Tue, Mar 9, 2010 at 11:03:08 AM | lineweight by material
col9000
Hi,
Im using revit 2009 and attempting to adjust line weights
I would like to have lineweights that take account of materials, so that (for example) in a wall containing both masonry and timber layers, the masonry layers would be outlined more heavily. Is this the purpose of the "materials" field in the object styles / model styles dialogue? Im not really sure what that field is supposed to do, or whether what I´m attempting is possible,
Any ideas?
Thanks
Tue, Mar 9, 2010 at 12:50:04 PM | lineweight by material
Lineweights are controlled through your Object Styles settings.  Walls are system level and the breakdown of styles in walls is limited to what the program has defined.  Basically that is the outer line of the wall and all interior lines are another setting.
So the answer is you can not do what you want through automatic settings.
Lineweight on Surface Patterns?
Mon, Jun 15, 2009 at 11:54:52 AM
Lineweight in perspecives
Wed, Sep 18, 2013 at 12:27:42 AM
Lineweight Problem
Tue, Jan 19, 2016 at 2:26:31 PM
Electrical Fixtures Lineweight
Tue, Jul 21, 2015 at 12:39:00 PM
Linked Cad - Global Lineweight
Wed, Sep 2, 2015 at 4:54:03 PM
Page generation time: 0.2109
