12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Roomtags not showing up
6 Posts No Rating |
I am using Revit 2010 and am having a problem with roomtags. When I move the roomtags outside of the room the tag loses it information. I have tried it with the leader box checked and unchecked. I really need to move the roomtags out of the room due to the size of the rooms, any suggestions? Thanks.
4 Posts No Rating |
I am creating ramp in revit architecture but now i want estimation on it. But ramp catagory is not present in material takeoff. Please help.
Are you selecting both the actual tag, and also the room area when you try move it?
6 Posts No Rating |
No, I am just selecting the roomtag. Do I need to select the room area as well?
yea you have to select the tag + the area and move at the same time... click on the tag, then hold ctrl key on keyboard and select the area. then move both...
6 Posts No Rating |
Thank you I will try it tomorrow when I get to work.
No... don't move the area. All you have to do is turn on the leader and move the tag. The leader will always point to the intersection of the X in the room area so you can move that intersection but if you move it outside the room, the room will no longer be bounded by the same boundaries.
Roomtags keep moving in wall sections |
Tue, May 8, 2007 at 6:39:49 PM
scale check |
Tue, Oct 23, 2012 at 5:05:08 AM
Cars not showing in renderings but showing in site plan, help hurry please |
Fri, May 6, 2011 at 6:01:49 PM
Revit in revit linked file |
Tue, Apr 8, 2008 at 9:13:41 AM
workstation room tags |
Thu, Jun 14, 2007 at 8:03:39 PM
