Forums >> Revit Building >> Technical Support >> room seperation lines
Mon, Mar 8, 2010 at 2:56:20 PM | room seperation lines
vblevin
Does anyone know how to make room seperation lines invisible (its not one of the line choices)?
Mon, Mar 8, 2010 at 3:08:41 PM | room seperation lines
Yes, it is a line... VG - Lines - expand that category and you will find it.
Mon, Mar 8, 2010 at 3:30:25 PM | room seperation lines
vblevin
sorry I dont understand. I went to
settings-linestyles-room seperation
and under line pattern invisible line is not one of the choices
Mon, Mar 8, 2010 at 4:16:35 PM | room seperation lines
Visibility Graphics VG controls all items in your views.  You need to open the view and type VG to change your settings.  In there, you can turn off the room seperation line.  You can not change it to an invisible linetype.  You can only turn it on/off - change its color/weight style.
Mon, Mar 8, 2010 at 5:01:05 PM | room seperation lines
vblevin
thank you
Rooms - editing room seperation lines
Fri, May 16, 2008 at 5:29:29 PM
Room seperation lines
Fri, May 12, 2006 at 5:19:35 PM
Room seperation
Fri, Dec 11, 2009 at 3:31:54 PM
Mysterious Room Seperator
Fri, Feb 3, 2012 at 2:39:06 PM
Room seperation at center of wall?
Sun, Jan 7, 2018 at 1:38:23 PM
Page generation time: 1.1907
