Forums >> Revit Building >> Technical Support >> How to add paint color to wall
Mon, Mar 8, 2010 at 2:52:02 PM | How to add paint color to wall
joycelaaa
Hello,
I am a student working on finishing my project. I am trying to render in color my floorplans/elevation.
 I am not able to change the paint color on the walls. How my I go about doing this? Any help would be appreciated.
 I am using the 2009 student version of Revit.
Thank you,
 Joyce
Mon, Mar 8, 2010 at 3:07:12 PM | How to add paint color to wall
If they are mostly one color, use that in the finish description of the walls.  Otherwise, you will have to either split up your walls by finish color and create new wall types or you can split the face of your walls and pour on a different finish with the paint bucket.
Mon, Mar 8, 2010 at 4:30:47 PM | How to add paint color to wall
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
select your wall, go to element properties, then go to "edit type"  then "structure"Cryingedit)
You'll see the makeup of your wall here, and in all likelihood, you've got six inches of gray default material.   If you click <By Category>, you'll see a (...) appear in the same box, and if you click this, it lets you set what material the wall is.  If you don't have many materials loaded into your project yet, you can always make more, by duplicating, and renaming, and changing the render appearance.
Paint Help
Wed, May 22, 2013 at 5:33:21 PM
How can I paint the wall the color I want?
Thu, Apr 3, 2008 at 6:59:35 AM
Changing Wall Paint color
Sun, Feb 7, 2010 at 7:02:40 PM
Creating a wall paint color
Wed, Dec 22, 2010 at 8:08:22 AM
Tag elevation by color
Tue, Apr 14, 2009 at 1:45:54 PM
Page generation time: 1.2042
