Forums >> Revit Building >> Technical Support >> underside of stair
Mon, Mar 8, 2010 at 11:24:52 AM | underside of stair
vblevin
I have a winder stair. How the heck do I model the underside of the stair as a flat surface so that I dont see the treads and risers?
Mon, Mar 8, 2010 at 11:45:50 AM | underside of stair
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Use sweep blend create path along spiral of stair, draw sections at top and bottom of stair. Read you manual about sweep blends.
Mon, Mar 8, 2010 at 12:01:47 PM | underside of stair
vblevin
can anyone offer a little more instruction please.
Mon, Mar 8, 2010 at 12:28:08 PM | underside of stair
4 Stars: 205 Votes
Just a question: Why don't you use the "Monolithic Stair"?
Mon, Mar 8, 2010 at 1:37:40 PM | underside of stair
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Attached are two files which will help you with understanding the sweep blend technique.
Mon, Mar 8, 2010 at 1:38:41 PM | underside of stair
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
This one is even better I did these a while ago.
Mon, Mar 8, 2010 at 2:47:51 PM | underside of stair
vblevin
thanks for the tutorila. And i tried to make it monolithis with smooth underside, but for some reason it still comes out stepped
Tue, Jun 24, 2014 at 9:17:50 AM | Curved monolithic stair w/ smooth underside
rduke
Hi Folks,
My firm trying to model part of a project in Revit to see if it would be a viable option for us going forward.  I've attached a project file of a spiral stair as well as a pdf of a cad drawing of what we'd like the stair to look like ultimately.  I have a couple questions.
-We'd like the underside of the stair stair to be smooth and to be able to modify the depth and profile of the stringer.  You'll see in the project file that the stair has a smooth underside but the stairs on the inside of the curve project into the the smooth underside.  I've tride adjusting the riser and tread thickness and have had no luck.  Is there any way to change the smooth underside or change the stringer profile on a monolithic stair.
-We'd like to have a bullnose step at the first rise.  Is there an easy way to do this?
Any advice you could give me or tutorials or relevant threads you could direct me to would be greatly appreciated.
Stair has strange curved underside
Thu, Aug 31, 2017 at 9:16:25 AM
Issues with underside of stair
Tue, Mar 15, 2011 at 3:27:07 PM
Curved Stair - Smooth Underside
Thu, May 3, 2007 at 9:54:55 AM
stepped underside of straight run monolithic stair
Tue, Dec 17, 2013 at 7:39:25 AM
Attaching a wall to underside of stair stringer
Fri, Nov 16, 2007 at 11:20:48 AM
Page generation time: 0.2913
