Forums >> Revit Building >> Technical Support >> Double Landing Stairs on single level
Mon, Mar 8, 2010 at 8:30:13 AM | Double Landing Stairs on single level
Hypno
Hi everyone,
 Just wondering if there is any possibility to create a double landing staircase between 2 levels.
 Revit Help Menu seems to only show stairs with single landing.
Having problem since, of course, working on a single floor plan makes my boundaries and risers overlap eachothers.
Thx alot, tell me if u dont understand Puh
Mon, Mar 8, 2010 at 8:34:22 AM | Double Landing Stairs on single level
Hypno
Btw, Revit 2009
Mon, Mar 8, 2010 at 10:02:03 AM | Double Landing Stairs on single level
EugenioFV
This is a good read on how to do this:
 http://www.revitcity.com/forums.php?action=viewthread&thread_id=8494
But I would seriously recommend doing 3 flights of stairs with their independent landings, or create the landings as floors. revit doesnt allow you to perfectly stack the landings under 1 stair as it will give you an error.
If you do use the above link, and create both landings under the same stair, remember than they will be offsett slightly from each other. If you are as compulsive as I am, seeing that minute separation between both levels is seriously going to bug you.
Good luck!
How to create a double landing stair (one top and btm)
Tue, Nov 1, 2011 at 7:47:28 AM
Multi level stairs with different heights
Tue, Dec 10, 2013 at 7:10:57 AM
stairs not connecting to landing- see attachment please!
Mon, Mar 5, 2012 at 12:29:45 PM
Revit Architecture 2008 Multi Level Stairs - Complex Building
Sun, Dec 4, 2011 at 4:39:37 AM
Stairs and Landings
Mon, Aug 3, 2009 at 6:50:57 PM
Page generation time: 0.3359
