Forums >> Community >> Newbies >> circuits
Sat, Mar 6, 2010 at 3:19:04 PM | circuits
Spartacus1
howdy,
i am trying to connect the lighting fixtures(277v 1va) to a 277/480v panel. here is the error message "Cannot assign or add H1 to Circuit. The Voltage (0 V) for the Circuit is out of range for the Line to Ground Voltage for H1 (The Line to Ground Voltage is specified in the assigned Distribution System)."
i made sure the voltage and VA are correct in the 3rd party Lithonia fixture(s). and then reloaded them and it still won't work. Any ideas what to do next?
thanks!
Sat, Mar 6, 2010 at 4:07:05 PM | circuits
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
SOUNDS TO ME LIKE YOU NEED A STEP DOWN TRANSFORMER IN THE DESIGN. YOU ARE DOING SOMETHING WRONG. THIS IS NOT A REVIT PROBLEM BUT A ELECTRICAL DESIGN FLAW.
Mon, Mar 8, 2010 at 12:38:46 PM | circuits
Spartacus1
i don't believe i need a step down xfmr when i am at 277V. (Line to Ground) thanks for you reply.
Fri, Sep 3, 2010 at 3:22:34 PM | circuits
jstutz04
make sure the connector voltage in your family matches your fixture voltage. also make sure that the fixture family has a connector on it
Revit Architecture 2013 Electrical Circuits
Thu, Jul 11, 2013 at 7:27:01 AM
Is there a way to show switch circuits in Revit MEP 2011
Thu, Mar 17, 2011 at 5:17:45 PM
One light fixture, two circuits?
Mon, Jul 14, 2008 at 9:18:24 AM
Electrical Circuits - odd and even number
Wed, Sep 22, 2010 at 1:16:55 PM
Dual Switching / Two Circuits to one Fixture
Wed, Aug 5, 2009 at 7:41:49 AM
Page generation time: 0.2092
