16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Column Visibility issues when attached to beams
1 Posts No Rating |
I am brand new to Revit - been playing with it for a couple weeks - Arch 2010 version. I am having a problem with columns. I am placing a canopy in front of my building, and when I attach the columns to the beams above, the columns are suddenly not visible on the floor plan. Also it causes the columns to show as hidden lines in elevation views. I have tried adjusting the view range and other view properties without success. They view perfect in the 3d view. Is there a setting I'm missing or is this some crazy autodesk fluke?
I had a similar problem with a column that attached itself to a floor, other columns around it were all visible but this one would disappear, I tried detaching the column from everything but it still wouldn't show up in plan only 3D. I couldn't use linework to get it to display either... Try copying the column & then deleting the orginal, & moving the copy back... This made mine show up, butI still have no idea why it disappeared in the first place...
column visibility issues |
Tue, Mar 11, 2008 at 12:08:15 PM
Concrete Beams not extending to Column C/L |
Wed, Jan 28, 2009 at 8:26:37 AM
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
Visibility issues |
Fri, Nov 27, 2020 at 6:12:45 PM
column grid visibility |
Wed, Nov 15, 2006 at 3:43:13 PM
