Forums >> Revit Building >> Technical Support >> 2X full scale
Fri, Mar 5, 2010 at 12:57:54 PM | 2X full scale
arcwiz
New to the forums.  My apologies if this is the wrong place for this question.
 I need to create a detail and set it to 2X full scale.  How do I do this?  If I try to create a custom view scale, scale value needs to be 1 : .5, it tells me I need to enter an integer.  Any help would be great.  Thank you.
Mon, Mar 8, 2010 at 1:06:34 PM | 2X full scale
arcwiz
I'm still having trouble showing a 2x scale detail. (for example, a metal panel joint).  has anyone done this before.  I would greatly appreciate some help.  thanks.
Mon, Mar 8, 2010 at 1:11:56 PM | 2X full scale
Sorry but I don't think you can.  And ... I have never seen a need to do this in any of my architectural work - I can't even remember when I used 6"=1'.
Mon, Mar 8, 2010 at 1:27:05 PM | 2X full scale
arcwiz
hmm.  ok, well thank you for the help.
Full Scale Printing
Mon, Sep 24, 2012 at 10:01:17 AM
Scale bar on sheet onto to display at certain scale
Wed, May 22, 2013 at 12:15:22 AM
scale image
Fri, May 13, 2016 at 1:11:44 PM
Scale Bar Link To Titlesheet Scale.
Thu, May 23, 2013 at 6:36:16 PM
scale check
Tue, Oct 23, 2012 at 5:05:08 AM
Page generation time: 0.1442
