Forums >> Revit Building >> Technical Support >> Angling an existing hatch pattern
Fri, Mar 5, 2010 at 11:25:11 AM | Angling an existing hatch pattern
benlink
I simply (one would think) want to have an earth hatch on an angle.  Though, I can't see a way to make that happen without creating an entirely new hatch (which I've never done and am trying to avoid at the moment).
Any suggestions?
Thanks.
Fri, Mar 5, 2010 at 11:29:35 AM | Angling an existing hatch pattern
TKennedy
4 Stars: 8 Votes
You will need a new .pat file, but you don't need to create it yourself. Search for 45° earth hatch and you chould be able to find one.
Fri, Mar 5, 2010 at 11:29:49 AM | Angling an existing hatch pattern
Use a model earth hatch pattern.  Model patterns can be rotated.  If you don't have a model earth hatch, you can create it by adding one line of text to your drafting earth pattern.  Add the folling line right after the title
;%TYPE=MODEL
Fri, Mar 5, 2010 at 12:06:09 PM | Angling an existing hatch pattern
benlink
Ok, so I've added an earth model pattern.  but when I try to save the file, it will only let me save it as a txt. file and not a .pat file.
Fri, Mar 5, 2010 at 12:17:56 PM | Angling an existing hatch pattern
How did you edit it...in word?  It is easier if you edited the pat file in wordpad or notepad but no matter, save as a txt file then rename it in your windows directory to a pat file.  Your windows has to be set up to show extensions.
Fri, Mar 5, 2010 at 1:38:48 PM | Angling an existing hatch pattern
benlink
Genius, yet again.  Thank you.
Fri, Mar 5, 2010 at 11:37:31 PM | Angling an existing hatch pattern
hugh
3.5 Stars: 4 Votes
This could bear repeating (from an earlier thread):
In Notepad specify "All Files" in the "Save As Type" field (that's the field below where you specify the filename) to avoid MS Notepad adding  .TXT to the saved filename. If you specify the  filename to be XYZ.PAT without selecting "All Files", Notepad will save the file you just named as XYZ.PAT with a ".txt" filename extension so you wind up saving the file as as XYZ.PAT.txt    - it's right up there as Notepad's most irritating quirk.
Hugh Adamson
www.hatchkit.com.au
Hugh Adamson
www.hatchkit.com.au
surface pattern hatch override
Tue, Apr 4, 2006 at 12:28:50 PM
Cut/Fill areas with different hatch pattern
Fri, Dec 18, 2009 at 11:21:44 AM
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:35 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Page generation time: 0.2486
