Forums >> Revit Systems >> Technical Support >> Fire extinguishers
Fri, Mar 5, 2010 at 9:35:40 AM | Fire extinguishers
koolair
4.5 Stars: 2 Votes
Hello, I have downloaded some fire extinguisher families from this site as well as Autodesk Seek.  They are in my fire protection folder of my library.
But when I load them in, I get a "no" symbol indicating the family cannot be placed anywhere.  I am on RME2009 on a 64bit machine running XP.
Hope someone's had success with this.
Thanks
Fri, Mar 5, 2010 at 9:43:24 AM | Fire extinguishers
TKennedy
4 Stars: 8 Votes
It may be a hosted family. Check to see if it asking you to place it on a face or work plane.
Fri, Mar 5, 2010 at 10:52:12 AM | Fire extinguishers
koolair
4.5 Stars: 2 Votes
yup, it's hosted and it won't let me place it on a wall either.
Fri, Mar 5, 2010 at 11:19:09 AM | Fire extinguishers
TKennedy
4 Stars: 8 Votes
Are you trying to put it on your wall, or a linked wall? Can you place it in another view type?
Fri, Mar 5, 2010 at 11:32:23 AM | Fire extinguishers
Kool - Are you placing from a plan view?  You should be able to place wall or wall face hosted from a plan view.  You can not place them from an elevation view.
Fri, Mar 5, 2010 at 11:36:09 AM | Fire extinguishers
koolair
4.5 Stars: 2 Votes
Yes, I'm doing it from plan view onto a linked wall, which normally isn't a problem (I've got wall hosted siamese connections and they work).
Fri, Mar 5, 2010 at 11:39:50 AM | Fire extinguishers
Wall hosted elements will not place on a linked wall.  You have to have face based.
Thu, Mar 11, 2010 at 11:58:40 AM | Fire extinguishers
Dingo46
Dingo46 Avatar
1 Stars: 1 Votes
however, you can copy/ monitor the linked wall and host to it.
Gary
Mon, Mar 22, 2010 at 10:59:48 AM | Fire extinguishers
koolair
4.5 Stars: 2 Votes
If I copy/monitor the linked wall, will I get problems in future revisions in the arch model?  How will it affect the speed of moving through the model?
I ask simply because in my plumbing model, all the sanitary was connected into one gigantic system and thus the speed was extremely slow.  So I just disconnected all the fixtures from it's drain pipe and now I have a gigantic network of pipes, but the calculations are not being re-done over and over, so the model is very fast.  I am hoping this copy/monitor won't bring back the old problems.
But it sounds like a cool idea.  I will think about it while waiting for some feedback on the above concern.  Hope to hear!
Joe
Mon, Mar 22, 2010 at 11:13:36 AM | Fire extinguishers
Dingo46
Dingo46 Avatar
1 Stars: 1 Votes
You can copy a wall from the Arch model and Not monitor it.  I try not to monitor too many things in the Arch model, just levels and grids. I would think things might slow down the more you monitor.  You will have no way of knowing if that wall was moved or even deleted without monitoring though.  But I'm sure, like the Architects I work with, they will tell you everything that was updated in their model ( heavy sarcasim)
 When you copy a wall, check out the options and select 'copy original type' that way you won't get a generic wall in its place.
Gary
Fire-tags
Thu, Apr 6, 2006 at 2:21:21 AM
formulas for fire rating.
Tue, Oct 14, 2008 at 8:24:03 AM
Fire Rated Walls Plan
Sat, Sep 8, 2012 at 11:31:19 PM
Fire or flame
Wed, Feb 6, 2013 at 11:00:11 AM
Fire door in front of elevator door
Thu, Feb 3, 2011 at 1:37:28 PM
Page generation time: 0.6191
