Forums >> Revit Building >> Technical Support >> Callouts & plan regions
Fri, Mar 5, 2010 at 8:45:43 AM | Callouts & plan regions
ivanvasc
Could someone answer me why plan regions are not avaiable in callout views? I've created a callout of a plan view, for detailing purposes, but my plan regions disapeared. Is it possible to fix it? Or plan regions really doesn't work in callout views. By the way, I'm using Revit 2010...
Thanks.
Ivan
Fri, Mar 5, 2010 at 9:13:12 AM | Callouts & plan regions
TKennedy
4 Stars: 8 Votes
Plan regions are view specific. If you have one on the same plan your callout is on, they won't automatically show up in your callout view. You will have to copy|paste aligned into your callout.
Fri, Mar 5, 2010 at 11:57:18 AM | Callouts & plan regions
ivanvasc
I've tried to copy and paste aligned. But it didn't work. The visibility in view is turned onBut the option plan region in the tool bar is not available (it's grey).Is there any tricky think to do?Thanks
HELP! callouts are not visible!!
Sat, Feb 16, 2008 at 12:17:21 PM
CALLOUTS IN PLAN PROBLEM
Fri, Aug 17, 2007 at 9:08:56 AM
Enlarged Plan callouts disappear
Thu, Jul 16, 2009 at 12:46:06 PM
Are Callouts Vew Specific?
Wed, May 12, 2010 at 3:56:06 PM
Detail Callouts missing! Latest build didn't fix!
Thu, Oct 25, 2007 at 10:03:55 AM
Page generation time: 5.3093
