Forums >> Revit Building >> Technical Support >> symbol/detail scale
Fri, Mar 5, 2010 at 4:24:49 AM | symbol/detail scale
nirim
5 Stars: 12 Votes
Hi there
I read somewhere in the forum that you can build symbol family and add a scale factor parameter, problem is I can not find that type of parameter when try to designate the parameter type. I want to be able to increase the size of the symbol in a view with a scale parameter regardless the view scale.
I am working on REVIT 2010
Fri, Mar 5, 2010 at 7:47:33 AM | symbol/detail scale
Symbols do not scale, they are the same printed size in every view.  If you want different sizes, you will have to create different symbols.
Fri, Mar 5, 2010 at 9:11:02 AM | symbol/detail scale
nirim
5 Stars: 12 Votes
Ahahah… but what if I want to be able to do that? I think the answer is to build the “symbol” as a detail family, so my question is still valid.
P.S thanks for the reply WWHub
nirim
Fri, Mar 5, 2010 at 9:22:41 AM | symbol/detail scale
Go ahead then and make your detail as you would any detail because those will scale with the drawing.  You can use reference planes with label dimensions to control your geometry.  You could use a (type or instance) scale factor parameter in formula's to control those label dimensions.
Fri, Mar 5, 2010 at 9:38:39 AM | symbol/detail scale
nirim
5 Stars: 12 Votes
That the thing WWHub, when I looked at the type parameter list in the dialog box I couldn’t find the scale factor parameter.
nirim
Fri, Mar 5, 2010 at 10:22:58 AM | symbol/detail scale
You have to create the parameter if you want it.... THERE IS NO SUCH THING BUILT INTO REVIT!  That is what I was telling you to do..."You could use a (type or instance) scale factor parameter in formula's to control those label dimensions."  .  You have to create formula's using a parameter (you called it scale factor) that would control the label dimensions.
Mon, Mar 8, 2010 at 3:06:39 AM | symbol/detail scale
nirim
5 Stars: 12 Votes
Back from busy weekend. I am now realizing that your solution is what I need to do but two remarks: A. If I need to re scale a symbol  (like the attach file) there are to many lines to control with the scale parameter, and B. Maybe it is something to add to the wish list, a real built in scale factor parameter to control the size of objects like 3D plants family  in landscape and 2D family.
nirim
how to create detail symbol
Wed, Mar 27, 2013 at 7:11:51 AM
new symbol from 2009 wont load as symbol in 2011
Wed, Jul 6, 2011 at 2:09:39 PM
Annotation Symbol Help.
Wed, Mar 12, 2014 at 12:30:48 PM
Annotation & Detail Component Families
Wed, Oct 16, 2013 at 12:23:57 AM
Symbol Text
Thu, Dec 10, 2009 at 5:39:08 PM
Page generation time: 0.9680
