Forums >> Revit Building >> Technical Support >> Changing Measure
Thu, Mar 4, 2010 at 7:35:36 AM | Changing Measure
seniorcad143
1 Stars: 1 Votes
When we use measure it gives us it in 256th of an inch.  Is there any way we can change that to give us the distance in a 16th of an inch?
Yeesh - Where is My Cad
Thu, Mar 4, 2010 at 8:14:50 AM | Changing Measure
4 Stars: 205 Votes
I use the Metric system but go to Options>Units or type UN and change the units you want...
Thu, Mar 4, 2010 at 8:15:44 AM | Changing Measure
You have several different settings in REVIT.  They are
Project Units - What Revit basically models to (We like to leave this at 1/256" so that when we import junk like CAD, we can see the errors.)  If you are seeing dimensions with x/256, then something is probably modeled wrong and you fix them immediately.  If you have snaps set right, you won't be seeing these in your temporary dimensions.
Dimension Units - You can set up as many different styles as you want.   In the styles you can set both text and units - I suggest you name these accordingly like Ariel 1/8 - Round 1/8" To set rounding - Look under Units Format
Snap settings .... Set the smallest increment you want to snap to and other logical snaps.
In addition to these, you may have unit settings in formula's and schedules.
Thu, Mar 4, 2010 at 8:22:01 AM | Changing Measure
seniorcad143
1 Stars: 1 Votes
So guys this will change the measure command and not just the dimension command, right?
Thu, Mar 4, 2010 at 9:02:57 AM | Changing Measure
TKennedy
4 Stars: 8 Votes
No, that only changes the dimensions. The tape measure will still use 1/256". As far as I know, that cannot be changed.
Thu, Mar 4, 2010 at 9:46:14 AM | Changing Measure
A x/256" dimension bothers you in a measure? ....Why?
If you are modeling correctly, you usually will never see this kind of dimension or measure.  If you are tracing CAD, then you will see this kind of dimension and I suggest you fix it.  You will find that parallel lines in CAD drawings may not be parallel in REVIT and that because of Rounding in CAD, you will get these x/256 measurements.
I believe your project units control the measure  tool but I would not set that unit higher.
Thu, Mar 4, 2010 at 10:45:02 AM | Changing Measure
seniorcad143
1 Stars: 1 Votes
It bothers me because when we scale something in the architects drawings it measures it to the 256th - oh wait a minute i just reread you post - so basically you are saying that the architect is not modeling correctly.  So if modeled correctly I should never get 256th increments.
Thu, Mar 4, 2010 at 1:28:14 PM | Changing Measure
TKennedy
4 Stars: 8 Votes
Correct. If you use the measure tool on the architect's stuff and come up with 137/256", then that's because they made it 137/256". My guess would be that at some point they traced a cad background at some point, that's about the only time I ever see those dimensions. If you want to get some rounded dimensions, you can just use the dimension tool, then erase the dims when you are done. It's a little more work, but it will give you a rounded dimension.
Mon, Jun 4, 2012 at 9:40:22 AM | Changing Measure
TMcGuire17
Thats BS! You should be able to set the measure tool as any other. So you measure a line that in autocad that has been OFFSET with the offset command at 7 3/4" in revit it measures with the measure tool at 7 195/256" so there is a deviation of .0117 apparently built in to autocad? You need to be able to adjust units of the measure tool as with any other units to eliminate this. We are building buildings not watches!
Mon, Jun 4, 2012 at 11:55:54 AM | Changing Measure
TKennedy
4 Stars: 8 Votes
I don't think there is a deviation built into Autocad (though there does seem to be some sloppy drawing at times), the deviation seems to come throught the .dwg to Revit translation. I don't know why it happens, but it most defenitely does.
I much prefer the meaure tool to not round. I want dimensions to round, but when I use the measure tool I want to know what the actual measurement is.
Measure tool running units
Mon, Jan 23, 2017 at 7:21:11 AM
Tape Measure Properties [ 1 2 ]
Thu, Aug 21, 2014 at 12:15:12 PM
18
How do you measure your revit modelling speed?
Mon, Jun 25, 2018 at 6:36:52 AM
measure tape in section doesn work
Tue, Mar 15, 2011 at 5:37:48 PM
scale problem
Mon, Jul 20, 2009 at 2:01:43 AM
Page generation time: 0.2438
