14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> Screening objects which appear beyond
2 Posts No Rating |
I am using structure 2010 and i am cutting a full height section thru a stage for a community theater project. I want to be able to see the stuctural elements beyond (columns, hangers, deeper beams, etc.) Is it possible for the objects in the foreground to screen out the elements which occur beyond where they cross them? The only way i can find to do it presently is using masking regions at the points of intersection. since members sizes, and elevations vary across the section it would take a lot of work to mask every point of intersection.
22 Posts No Rating |
Can you accomplish this by adjusting your Model Graphics Style (at the bottom of the section view window)? Use "Hidden Line" for example instead of "Wire Frame"? Unless your in a Wire Frame view, solid objects in the front should mask out things behind them.
Screening |
Sat, Mar 5, 2005 at 1:26:18 PM
Screening objects in the background |
Wed, Mar 3, 2010 at 2:12:21 PM
Importing AutoCAD Linetype Screening Values into Revit |
Fri, Jul 27, 2007 at 12:53:09 PM
Elaveation / Section Lineweights by depth. screening by distance. |
Fri, Aug 18, 2006 at 10:39:34 AM
Patterns generated by algorithyms for screening panels |
Mon, Jul 15, 2013 at 10:41:47 PM
