26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Turn on/off door threshold in project
78 Posts No Rating |
I am currently using the generic Single-Flush door in one of my projects. What I would like to do is add a threshold to the door (basically just 2 lines at the faces of the wall) that has the ability to be turned on and off. For example, I want to use the same door family for all the single flush doors in the rooms but the door to the bathroom will have a threshold denoting a change in material. I am not sure how to do this. Do I need to create a nested family for the threshold with nominal thickness? How do I add the parameter to turn it on and off? Thanks for the help
You could do it with a nested family or just place symbollic linework in the family. I created a new sub-category for thresholds in ours so that I can turn them off in views where I don't want them to show. The visibility of this linework is controlled by a Y/N shared parameter that is instance based.
I always thought that dogs laid eggs... and I learned something today. Thanks Double-Dub-Hub
Zero threshold door. |
Thu, Oct 24, 2024 at 11:50:45 PM
Adding Level Thresholds to Doors |
Thu, Nov 23, 2006 at 4:43:12 AM
Visibility of Door Thresholds |
Wed, Jul 1, 2009 at 9:50:17 AM
Nested Door Families and Door Schedules |
Mon, Nov 8, 2010 at 2:56:46 PM
Can we set our own constraints and if yes how? |
Thu, Mar 31, 2005 at 9:06:01 AM
